Written Date: October 20, 2006
User Rating:
/ 0
Hits:
1,393
In Visual Paradigm for UML and Smart Development Environment, there is a feature named Instant Generator for generating source from class model. Instant Generator supports a set of language such as C++ and Java. The below steps will describe the C++ source generation.
Supporting Language
| The below languages are supported by Instant Generator. |
| • Java |
• C# |
• VB .NET |
• PHP |
• ODL |
• ActionScript |
• IDL |
• C++ |
• Delphi |
• Perl |
• XSD |
• Python |
• Objective-C |
Classes and Relationships Modeling
| Class model is required before generation. To provide class model, open an existing VP project or model a new one. |
Instant Generator Dialog
| Instant Generator has a primary user interface called Instant Generator Dialog. It providing almost all interface of Instant Generator such as configuration, preview and generation. On top menu, click Tools > Instant Generator > Instant Generator... to open Instant Generator Dialog. |
General settings
| As configuration is simplified, only three values are required to input even first time generation. |
| 1. |
Select Language to specify which language of source will generated for. In this example, C++ is selected. |
| 2. |
Choose class(es) or package(s) which will be included of the generation. |
| 3. |
Select output path for placing generated source. |
Language specified options
| For each language, specified options may provided for additional control. These options are organized into two kinds of options, Basic options and Advanced options. |
Basic options |
Those common change options are grouped in Basic options and allow to edit directly in Instant Generator Dialog. |
Advanced options |
Advanced options contains all options of the language including options in Basic options. To edit Advanced options, click Advanced Options in Instant Generator Dialog. |
Preview or Generate
| As different values of options will produce different generation result, Instant Generator provides preview of generation result before the actual generation. |
Press Preview in Instant Generator Dialog to preview generation result. |
Press Generate in Instant Generator Dialog to perform actual generation. |
While the generation, the progress is displayed in Generator Output. |
The generated sources are generated in output path. |
Open output folder can simply perform by pressing Open output folder in Instant Generator Dialog. |
To close Instant Generator Dialog, simply press Close. |
Samples
Related Resources
Comments (0)
