Set Application's Font
Visual Paradigm for UML (VP-UML) uses the best possible font for its user interface. However, in case, the default font setting appears to be too blur and illegible for users, the font setting used in the application user interface is allowed to be customized with users' preference starting from VP-UML 8.0. In this tutorial, you can learn how to customize the application font in VP-UML.
August 16, 2010
User Rating: / 0
PDF Link Add comments
Edition: Community or above (Edition comparison)
  1. After entering VP-UML, select Tools > Options... from the main menu to open the Options dialog box.
    click options
  2. In the Options dialog box, select General page and open Appearance tab.
    appearance tab
  3. Check Change application font.
    check change font
  4. Now, you can change the font and its size. Select Artial Black from the drop-down menu of Font.
    select font
  5. Select 12 from the drop-down menu of Size.
    select font size
  6. Click OK button in the Options dialog box.
  7. In the pop-up Message dialog box, click OK button. It notifies you to restart the application.
    message
  8. Finally, restart the application. Close the current screen and launch your VP-UML.
  9. As you can see the application font is changed as shown below:
    font changed
Rate this Article
Click on one of the stars below to rate this article from 1 (lowest) to 5 (highest).
You may be interested in
  1. Writing Effective Use Case
  2. UML Package Diagram
  3. Draw Entity Relationship Diagram (ERD)
  4. Produce UML Use Cases from Business Process Diagram (BPD)
  5. Draw UML Sequence Diagram with Keyboard
Tags of this article:
Comments (0)
Write comment
Rating
Comment
Enter the calculation result
security code
