Discussion
When team members start to study a Requirement, to try supporting it, there may be questions or suggestions that worth sharing with project manager, developer, or someone else responsible. The discussion function is designed to let team members share their opinions about Requirements. Team members can add a discussion post and assign to teammates to seek for a reply.
Post a discussion
  1. Open the Requirement you need to add a discussion post.
  2. Under the Requirement, click on the Discussions section.
    Open the Discussion section
  3. Enter the discussion body.
    Fill in discussion body
  4. Add the member(s) to notify through the Notify drop down menu. To add multiple members, click + and add those members.
    Add member to notify
  5. If you want to add any file to your follow-up for supporting your message, click on the Attach a file link and then click Browse to supply the file.
  6. Click Post Message.
Reply a discussion
When someone has created a discussion post and have added you for notification, you can see an entry of that discussion in the Home page, under the Discussion widget.
  1. Open the Home page.
  2. Check the Discussion widget. Click on the link of Discussion to open it.
    Open a discussion
    Open a discussion
  3. Click Reply at the top right of the post you want to reply.
    To reply a discussion post
  4. Enter the Body of your reply.
    Enter the body of reply
  5. Initially, the person who notifies you would be selected in the Notify drop down menu, meaning that he/she will be notified when you post your reply. If you want to update the member(s) to notify, click on the Notify drop down menu and update the selection. To add multiple members, click + and add those members.
Edit a discussion
The person who posted a discussion or a reply of discussion can modify the content of his post. To edit a post, click Edit. Fill in the post and click Save.
Edit a post
Edit a post
Delete a discussion
The person who posted a discussion or a reply of discussion can delete his post. When a post is deleted, the post and the replies of that post will be deleted, too. To delete a post, click Delete and confirm the deletion.
Delete a post
Delete a post
7. Revision Table of Contents 9. Time log
Technical Support
Sales Support
Discussion Forum
