User Path Options
A user path is a variable that refers to a base path in user’s computer. You can add a reference to local file using user path so that the reference refers to a file relative to a user path, instead of an absolute path. This means you can move references files to a different location, or even to a different computer, and can still open them as long as the user path value is up-to-date.
Option Name
Description
Show user path
(default false) Select to show user paths in references, instead of displaying resolved absolute paths. A user path is displayed with its name enclosed by ${ }.
Prompt to specify user path
(default false) When adding a reference comprises a path that is not defined as a user path, you will be prompted to add path as user path.
User Path Options details
Chapter 5. User Path Table of Contents Chapter 6. File Types
Technical Support
Sales Support
Discussion Forum
