Model Generation Options
Option Name
Description
Default generate diagram type from scenario
  • Sequence Diagram - (default) Take Sequence Diagram to be the type of diagram that will be generated by Scenario
  • Interaction Overview Diagram - Take Interaction Overview Diagram to be the type of diagram that will be generated by Scenario
ID Generator Format Specify the ID format of various element types. If you want ID be generated to a type of model element and you find the type does not exist in the table, click Add to add the type manually. Then, specify the format of ID by specifying prefix, number of degits and suffix.
Model Generation Options details
2. Environment Table of Contents 4. Shape
Technical Support
Sales Support
Discussion Forum
