Association Options
Option Name
Description
Show association stereotype (default true) Show the stereotypes assigned to an association.
Show from role name (default true) Show the role name of the from end of association.
Show to role name (default true) Show the role name of the to end of association.
Show from role visibility (default true) Show the role visibility of the from end of association.
Show to role visibility (default true) Show the role visibility of the to end of association.
Show from multiplicity (default true) Show the role multiplicity me of the from end of association.
Show to multiplicity (default true) Show the role multiplicity of the to end of association.
Show multiplicity constraints (default false) Show multiplicity constraint such as {unique} for roles.
Show direction (default false) Show a triangle mark on association for indicating direction.
Show association role stereotypes (default true) Show stereotypes assigned to role.
Default Association End Navigable
  • Unspecified - A new association will set Navigable as Unspecified for both ends
  • True - (default) A new association will set Navigable as True for both ends
  • False - A new association will set Navigable as False for both ends
Default Association End Visibility
  • Unspecified - (default) A new association will set Visibility as Unspecified for both ends
  • private - A new association will set Visibility as private for both ends
  • protected - A new association will set Visibility as protected for both ends
  • package - A new association will set Visibility as package for both ends
  • public - A new association will set Visibility as public for both ends
  • protected internal (.NET only) - A new association will set Visibility as protected internal for both ends when programming language is set to be .NET
  • internal (.NET only) - A new association will set Visibility as internal for both ends when programming language is set to be .NET
Suppress implied "1" multiplicity for attribute and association end (default false) Suppress implied "1" multiplicity for attribute and association end.
Synchronize association name with association class
  • Prompt - Prompt if you want to make the name of association follow the association class when creating the association class
  • Yes - Make the name of association follow the association class when creating the association class
  • No - Do not make the name of association follow the association class when creating the association class
Association Options details
6. Class Table of Contents 8. Generalization
Technical Support
Sales Support
Discussion Forum
