Installing Agilian on Mac OSX
Having downloaded the installer of Visual Paradigm Suite (VP Suite), you can execute it, run through the installation to install the suite as well as Agilian. If you are using the "no-install" zip version, you just need to unzip it, launch the suite and install Agilian. In this chapter, we will go through the installation of Agilian both with installer (.dmg) and "no-install" (.tgz).
Using installer (.dmg)
  1. Execute the downloaded VP Suite installer file. The setup wizard appear as below.
    VP Suite Welcome screen
  2. Click Next to proceed to the License agreement page.
  3. Read through the License Agreement carefully. Make sure you accept the terms before continuing with the installation. If you accept the agreement, select I accept the agreement and click Next > to proceed to the Select Destination Directory page.
    The License Agreement
  4. Specify the directory for installing VP Suite. Click Next > to proceed to the next page.
    The Select Destination Directory page
  5. In the File Association page, keep Visual Paradigm Project (*.vpp) and Visual Paradigm License File (*.zvpl) checked if you want your system able to open the project file and the license key file. Click Next > to proceed to the product selection page.
    The Select File Associations page
  6. Select Agilian. Click Next > to proceed to the product selection page.
    The product selection page
  7. Agilian features vary by product edition. For more details on the features supported by different editions, click the hyperlink Edition Comparison which brings you to the web page of Agilian feature comparison for different editions. Select the edition to be installed.
    Select product edition
  8. For users who are going to run Agilian with floating license, the Pre-Configuration File section enables you to configure the connection(s) to floating license server by providing a configuration file. The pre configuration is optional. If you do not define the connection here, you will need to do so when starting Agilian the first time. Below is the pre-configuration file file content:
    ?xml version="1.0" encoding="UTF-8"?>
    <LicenseServer>
        <Server accessCode="" host="" port=""/>
    </LicenseServer>
    Pre-configure floating license server connection for floating license user
  9. Click Next > to proceed to the file copying process.
  10. Upon finishing, you can select whether to start Agilian or not. Keep Agilian selected and click Finish will run Agilian right away.
Using "no install" version (.tgz)
  1. Decompress the downloaded zip file into a directory. This should create a subdirectory named "VP Suite 4.2" where 4.2 is the version number.
    Extracting No-Install zip file
    Extracting "No-Install" zip file
  2. Change directory to "VP Suite 4.2/bin" and execute VP Suite in it.
    Launching VP Suite
    Launching VP Suite
  3. Select Agilian. Click Next > to proceed to the product selection page.
  4. Agilian features vary by product edition. For more details on the features supported by different editions, click the hyperlink Edition Comparison which brings you to the web page of Agilian feature comparison for different editions. Select the edition to be installed.
  5. Click Next > to continue.
  6. Upon finishing, you can select whether to start Agilian or not. Keep Agilian selected and click Finish will run Agilian right away.
Installation FAQ
Question: What is the difference between Installer and "No Install" Version?
Answer: Installer version creates shortcut and registers the menus that make the system more easy to use. We suggest user to use installer version for a long term usage. The "No Install" version is good for evaluation and testing the release candidate.
Question: I cannot complete the installation due to a file is missing when copying files. What can I do?
Answer: This can be caused by a corrupted installer file. Please download the installer file again with a different mirror site and run it again to solve the problem.
Question: I cannot start the application after installing the software. What can I do?
Answer: There are several possible causes of the problem. If you are sure that your installation was performed correctly, contact Visual Paradigm's support team (support-team@visual-paradigm.com) for assistance. It is recommended to include the vp.log file, which can be found at the bin folder of VP Suite installation directory, for our team to diagnose in further.
Question: Can I change the Edition without re-install the software?
Answer: Yes, you can. Product edition can be changed by running VP Suite Product Edition Manager under the bin folder of VP Suite installation directory. Change of edition takes effect after the restart of affected products. For more details, please read the section Switching Edition a few pages later.
Question: The installer file is detected to contain a virus. What can I do?
Answer: Our installer files are all packed by ourselves in a secure environment, and are scanned for virus before releasing to public. If a virus is detected, please update to the latest virus profile first. After that, we recommend you perform a full system scan, download the installer file from our official site, and run the installation again. If the problem remain, please contact us (support-team@visual-paradigm.com) or the virus scanner vendor for assistance.
1. Windows 2000/NT/2003/XP/Vista/7 Table of Contents 3. Linux and Unix
Technical Support
Sales Support
Discussion Forum
