Starting Agilian
Ways of starting Agilian
Agilian can be launched through accessing the Start Menu.
Start Agilian via Start Menu
For Linux users, Agilian can be started through the shortcuts in desktop, created by the installer.
Starting Agilian (for floating license client whose host is IP-4-enabled)
If you are a floating license client, and if your host is IP-4 enabled, you need to start Agilian with a startup script in order to connect to the server. Here are the steps:
  1. Copy Agilian.bat under the scripts folder of VP Suite installation directory to become Startup.bat
  2. Edit Startup.bat
  3. Add -Djava.net.preferIPv4Stack=true to the script
    Editing the start up script
  4. Save
  5. From now on, execute Startup.bat to run Agilian
Select workspace
A workspace is a directory used to store all settings, user interface perspectives and other preferences defined for the working environment (settings can be configured via Tools > Options... in Agilian). A workspace also stores all the teamwork login information and local copies of teamwork projects. In the case of switching computers, you simply need to copy the whole workspace directory to the new computer and specify the new workspace when starting Agilian. All your teamwork information and settings will then be transferred to the new computer.
The Workspace Launcher appear when running Agilian.
Workspace Launcher
Workspace Launcher
Specify the workspace folder.
If you do not want this dialog box to appear again, check Use this as the default and do not ask again. This will cause Agilian to open the specified workspace folder automatically the next time.
If you already have an existing workspace, you can import the settings from there by clicking Import Workspace....
Click OK to continue.
Chapter 3. Getting started Table of Contents 2. Interface Overview
Technical Support
Sales Support
Discussion Forum
