Menu bar
The main menu, which is on the top of the window, allows you to select and perform various operations in Agilian.
File menu
The File menu
The File menu
The File menu enables you to:
  • Create a project
  • Create a diagram
  • Open project
  • Save project
  • Save and manage project template.
  • Import project data from the following media: Agilian Project, Rose Project, XMI, XML, ERwin Project, Telelogic Rhapsody Project, Telelogic System Architect, Rational Model, Rational DNX, PowerDesigner DataArchitect, MS Word (Use Case Model documentation exported from VP), Excel (Exported from VP), Visio, NetBeans
  • Export project into the following formats: Agilian Project, XMI, XML, MS Word (for Use Case Model), Excel
  • Export images (JPG, PNG, SVG, EMF, PDF)
  • Printing
  • Set project properties
  • Exit
Edit menu
The Edit menu
The Edit menu
The Edit menu enables you to:
  • Undo and Redo
  • Cut
  • Copy
  • Duplicate
  • Delete
  • Change the end model element of connector
  • Repeat an action
  • Select everything in diagram
  • Find a model element/diagram
  • Jump to a diagram or an element
  • Add or manage bookmarks
  • Grouping
  • Shapes alignment and distribution
View menu
The View menu
The View menu
The View menu enables you to:
  • Show/Hide a pane
  • Show and manage grid
  • Manage Layers
  • Change Resource Centric behavior
  • Save, open and manage perspective
  • Change Agilian to show in full screen
  • Zoom diagram in and out
  • Manage nickname
  • Manage style
  • Auto spell check
Modeling menu
The Modeling menu
The Modeling menu
The Modeling menu enables you to:
  • Launch Animacian
  • Launch Simulacian
  • Compare diagrams with Visual Diff
  • Perform use case scheduling
  • Configure stereotypes
  • Configure requirements
  • Customize use case ranks
Tools menu
The Tools menu
The Tools menu
The Tools menu enables you to:
  • Generate report
  • Publish project
  • Configure programming language
  • Perform ORM
  • Perform State Machine Code Generation
  • Perform Visio integration
  • Launch Shape Editor
  • Launch License Key Manager
  • Configure application options through the Options dialog box
Teamwork menu
The Teamwork menu
The Teamwork menu
  • Commit changes
  • Update changes
  • Tagging
  • Branching
  • Merge
  • Revert changes
Window menu
The Window menu
The Window menu
The Window menu enables you to:
  • Navigate between diagrams
  • Rearrange diagram windows
  • Switch to another diagram
  • Show the Start Page
  • Close other diagrams, except the active diagram
  • Close Diagrams
Help menu
The Help menu
The Help menu
The Help menu enables you to:
  • Browse the help contents
  • Check the instruction of Mouse Gesture
  • Visit Visual Paradigm online support
  • Repair project
  • Customize the user interface
  • Check the environment using the About dialog box
Chapter 4. User interface Table of Contents 2. Toolbar
Technical Support
Sales Support
Discussion Forum
