Technical Support
Sales Support
A toolbar can be shown or hidden. To show a toolbar, right click on the standard toolbar, and check Standard to show. Similarly, you can uncheck it to hide it.
| Show or hide toolbar |
A toolbar can be repositioned by pressing on the handle of toolbar, which appears on the left edge of a toolbar, and dragging it to your target position.
| Drag the left edge of toolbar |
To freeze toolbars' position and make the toolbars immovable, right click on any toolbar and uncheck Rearrangable from the pop-up menu.
| Uncheck Rearrangable option |
| The Standard toolbar |
| Icon | Name | Description |
| New Project |
Create a project. | |
| Open Project |
Open a project. | |
| Save Project |
Save the changes made in the working project. | |
| Print... |
Select and print diagram(s) after configure the advanced printing set up. |
Print Active Diagram... | Print the active diagram after configure the advanced printing set up. |
Quick Print... | Select and print diagram(s) after configure the simple printing set up in Quick Print dialog box. |
| Cut |
Cut selected diagram elements. | |
| Copy within AG SN |
Copy selected diagram elements ready to be used within Agilian. | |
| Copy to Clipboard as Image (JPG) |
Copy selected diagram elements as JPG image. | |
| Copy to Clipboard as Image (EMF) | Copy selected diagram elements as EMF image. | |
| Copy to Clipboard as XML |
Copy selected diagram elements as XML data. | |
| Paste View |
Paste copied diagram elements as view of original model element. | |
| Paste Model Element | Paste copied diagram elements as a new model element. | |
| Undo |
Roll back undesired changes. | |
| Redo | Rerun an undone task. | |
| UML Modeling |
Select and create a diagram type under UML Modeling, including: Use Case Diagram, Use Case Grid, Actor Grid, Class Diagram, Composite Structure Diagram, Object Diagram, Sequence Diagram, Communication Diagram, Activity Diagram, State Machine Diagram, Timing Diagram, Interaction Overview Diagram, Component Diagram, Deployment Diagram and Package Diagram. |
| Business Process Modeling |
Select and create a diagram type under Business Process Modeling, including: Business Process Diagram, Conversation Diagram, Data Flow Diagram, Event-driven Process Chain Diagram, Process Map Diagram, Organization Diagram and ArchiMate Diagram. |
| Database Modeling |
Select and create a diagram type under Database Modeling, including: Entity Relationship Diagram and ORM Diagram. |
| Requirement Modeling |
Select and create a diagram type under Requirement Modeling, including: Textual Analysis, Requirement Diagram, Basic Diagram, Open Requirements Grid, Open Glossary Grid and CRC Card Diagram. |
| Impact Analysis |
Select and create Matrix Diagram. |
| Diagrams |
Select and create other diagrams, including: EJB Diagram, Overview Diagram, User Interface and Mind Mapping Diagram. |
| Format |
Click it to open Formats dialog box. You can format font name, font style, font size, font color, line style, shape's foreground and background color and style, etc. |
| Copier |
Copy the selected diagram element's format and apply on another shape. | |
| Modeling |
Click it to perform the following: Visual Diff, Animacian, Simulacian, Nicknames, Apply Design Pattern and Transit to New Diagram. |
| Generate HTML Report |
Open the Generate HTML dialog box to generate HTML report. | |
| Generate PDF Report |
Open the Generate PDF dialog box to generate PDF report. | |
| Generate Word Report |
Open the Generate Word dialog box to generate Word report. | |
| Report Writer |
Open Report Writer where you can create and edit your report(s). |
| Project Publisher |
Publish project to Web pages through Project Publisher. | |
| Open Teamwork Client |
Open the Teamwork Client dialog box. | |
| Commit |
Commit changes to server. | |
| Update |
Update changes from server. | |
| Tag |
Create a tag. | |
| Branch |
Create a branch. | |
| Merge |
Merge changes between trunk and branches. | |
| Switch |
Switch between trunk, branches and tags. | |
| Revert |
Click it to undo all non-committed changes in working project. |
| Generate Code |
Generate state machine code from class diagram and state machine diagram. | |
| Reverse Code |
Reverse state machine code back into the opening project. | |
| Interoperability |
Import: Agilian Project: Import an Agilian project into the opening project. Export: Agilian Project: Export the open project into an Agilian project file. |
| 1. Menu bar | Table of Contents | 3. Dockable User Interface |
Technical Support
Sales Support
