Technical Support
Sales Support
Diagram navigator is the location where diagrams are listed. You can create your own diagrams easily as they are listed by categories, such as UML Diagrams, Requirements Capturing, Database Modeling, Business Process Modeling and Others. With diagram navigator, you can create, open and delete diagrams.
| The diagram navigator |
| The description of icons on diagram navigator |
| The pop-up menu of diagram navigator |
| The description of pop-up menu of diagram navigator |
| The pop-up menu of project node in diagram navigator |
| The description of pop-up menu of project node |
| The pop-up menu of diagram category in diagram navigator |
| The description of pop-up menu of diagram category |
| The pop-up menu of diagram type in diagram navigator |
| The description of pop-up menu of diagram type |
| The pop-up menu of diagram in diagram navigator |
| The description of pop-up menu of diagram |
Diagram navigator is opened by default. To close it, press the X button at the top right corner. On the other hand, it can be opened by selecting View > Panes > Diagram Navigator from the main menu.
Approach 1 – Direct creation
If you want to create a diagram in a quick way and don't need to supply the documentation of diagram (for time-saving), use this approach. To create a diagram:
| NOTE: | You can immediately enter the diagram name at the top left corner of diagram. |
Approach 2 – Through the New Diagram dialog box
This approach let you create a diagram and enter the name and documentation simultaneously. To create a diagram:
In the New Diagram dialog box, you can enter the name and documentation of diagram, and click OK to proceed.
| New Diagram dialog box |
Double click the diagram you want to view in the diagram tab.
In diagram navigator, diagram elements are listed under diagram nodes. You can sort diagram elements by their names, or by their types (e.g. use case, package, etc.)
To sort by name, click Sort Diagram Element by Name button. The elements will be listed by name, in alphabetical order.
| Click Sort Diagram Element by Name |
To sort by type, click Sort Diagram Element by Type button. As a result, the elements will be listed by type.
| NOTE: | The sort function applies to the entire diagram tree instead of the selected node. |
Select the diagram(s) you want to reorder. If there are multiple diagrams you want to select, just click one while pressing Ctrl button and make the other selection.
Click Move Selected Diagram Up button to move the selection upwards, or Move Selected Diagram Down button to move the selection downwards.
You can choose which model elements you want to be displayed or not on the diagram tree.
| Model Element Filtering dialog box |
| NOTE: | You can check Display model element types in-use to list only types of model elements used in project. The text box Filter enables you to filter model element type base on the type name (e.g. enter class to list only class) |
If it is the case that the name of the diagram and diagram elements is in multi-line, the character ¶ will be revealed.
When Show Carriage Return Character is selected, line break will be shown.
| Show carriage return character |
When deselected, the character ¶ is hidden.
If you want to hide it, right click on the diagram navigator's background and uncheck Show Carriage Return Character from the pop-up menu. As a result, the character will automatically be unshown.
As it is said before, default groups are automatically arranged by category.
If you want to ungroup diagram:
| Ungrouped diagrams |
Agilian's team collaboration support enables your team members work together on projects. To connect to server and perform related activities:
| Perform teamwork |
If you only want the diagram nodes to be shown but not the diagram elements under them, just click on Show Diagram View button on its toolbar.
| NOTE: | This option applies to all diagram nodes, but not just the selected one. |
| 3. Dockable User Interface | Table of Contents | 5. Model explorer |
Technical Support
Sales Support
