Technical Support
Sales Support
Class repository is a pane where classes and container that contain classes, such as packages or subsystems, are listed. To access classes, you can also form class diagram by dragging classes from class repository on class diagram.
| The Class Repository |
| The description of icons on Class Repository |
| The pop-up menu of Class Repository |
| Menu Title | Description |
| Model |
Create a model. |
| Model Element... |
Create a new model element in Class Repository instead of creating through diagramming. |
| Show Carriage Return Character |
Display line breaks of multi-lined diagram name as carriage return character. |
| Teamwork |
Perform teamwork activities. |
| Manage Dependent Project... |
Add or remove dependent project. |
| Refresh |
Refresh Class Repository content. |
| Collapse All |
Collapse all tree nodes. |
| Expand All |
Expand all tree nodes. |
| The pop-up menu of project node in Class Repository |
| No View Model Elements... | It lists the model element(s) that either has not been visualized (no view) or has no master view. |
| Rename... |
Rename the project. |
| Nicknames |
Configure or switch to another nickname. |
| Model |
Create a Model. |
| Model Element |
Create a new Model Element in Class Repository without the need of creating through diagramming. |
| Configure Programming Language... |
Change to another programming language or configure the type mapping for a language. |
| Teamwork |
| Refresh |
Refresh Class Repository. |
| Collapse All |
Collapse the project node. |
| Expand All |
Expand the project node. |
Class Repository is opened by default. To close it, press the X button at the top right corner. On the other hand, it can be opened by selecting View > Panes > Class Repository from the main menu.
A model is a package like UML element that can store model elements and diagrams. Users are recommended to structure project by using model in order to maintain a clear structure for accessing project data and improve the application performance.
Right click on the root node in Class Repository and select Model > New Model... from the pop-up menu to create a new model.
| Select New Model in pop-up menu |
A model element is created when you create a shape on a diagram. If you want to create a model element without visualizing it, you can create it through the Class Repository. To create a model element:
| Select New Model Element in pop-up menu |
If it is the case that the name of model elements is in multi-line, the character ¶ will be revealed.
When Show Carriage Return Character is selected, line break will be shown.
| Show Carriage Return Character is revealed |
When off, the character ¶ is hidden.
If you want to hide it, right click on the diagram navigator's background and uncheck Show Carriage Return Character from the pop-up menu. As a result, the character will automatically be unshown.
Agilian's team collaboration support enables your team members to work together on projects. To connect to server and perform related activities:
| Perform teamwork |
| 5. Model explorer | Table of Contents | 7. Logical view |
Technical Support
Sales Support
