Technical Support
Sales Support
Agilian stores information like model elements and diagrams in a project. Therefore, you need to create a project before performing modeling. To create a new project, select menu File > New Project from the main menu. When the New Project dialog box pops out, click Create Blank Project button to create a new project.
| Create a new project from the main menu |
| An overview of New Project dialog box |
| Description of New Project dialog box |
To create a blank project, ensure the Properties page is being selected, and then click the Create Blank Project button.
| An overview of Properties page |
| Description of Properties page |
If you often create projects of similar structure, you can save the project as a template and use it for creating project later. For example, you can save a project with a use case diagram and a class diagram as template called "Static Modeling Template". When we create project from this template, the project will have the same structure as the template automatically.
To create project from template, select the Template page and select a template to use, then click the Create From Template button.
| An overview of Template page |
| Description of Template page |
If you have legacy projects created with other CASE tools, you can import them to Agilian. Select either to import from Rose or from XMI, specify the file path of source to import and click Create From Other CASE Tools at the bottom of dialog box.
| An overview of Other CASE Tools Project page |
| Description of Other CASE Tools Project page |
| Chapter 5. Working with projects | Table of Contents | 2. Saving project |
Technical Support
Sales Support
