Technical Support
Sales Support
A model element is an elementary component of a model. It will be created when you create a shape on a diagram, or when we create one directly through the Model Explorer. An example of model element is use case.
| Creating a model element through Model Explorer |
You can visualize an existing model element by dragging and dropping a model element from Model Explorer to diagram. We call the visualized form of model element a view, or a shape, depending on whether we want to emphasize the differences against model elements, or we want to focus on diagramming operations.
| Creating a view from an existing model element through drag and drop |
When developing context-based diagrams, you will reuse a model element in different diagrams, resulted in creating multiple views. Each model element can associate with zero to multiple views. When you make specification-level change, such as changing name, on any view, the change will be applied to all views.
If you want to open a diagram from a model element, right click on the model element in Model Explorer and select Show View... from the pop-up menu. Then, select the view to open in the Show View dialog box and click Go to View to open the diagram.
| Chapter 6. Key concepts | Table of Contents | 2. Master view and auxiliary view |
Technical Support
Sales Support
