Technical Support
Sales Support
The feature of use case details refers to the basic information, flow of events, requirements and test plan of a use case. Documenting use case details is essential in recording meaningful and important information for a use case.
To start editing and viewing use case details, right click on the target use case in use case diagram and select Use Case Details... from the pop-up menu.
| Select Open Use Case Details... |
Basic information refers to all general information of a use case. Rank and justification determine the importance of use case. Select a rank from the drop-down menu and enter the text in Justification text field.
Primary actors list the actors being involved in a use case. Actors that are connected to a use case are automatically defined as primary actors. Supporting actor are actors who are beneficial from the system, but without direct interaction. Both primary and supporting actors can be added manually by pressing the Plus button and select the actors in the pop-up dialog box.
| Basic information of use case |
Flow of events refers to the steps required to go through and fulfill a use case. You may define multiple flows of events under a use case and add extension to an event as well. For more information about documenting flow of events, read the next chapter Documenting Flow of Events.
| Flow of events of use case |
Details are predefined and detailed fields of a use case, which includes level, complexity, status, implementation status, preconditions and post-conditions, author and assumptions. Select an option for Level, Complexity, Use Case Status and Implementation Status from the drop-down menu.
| Details of use case |
| Click Insert Requirement... button |
| Select a requirement |
Requirements of a use case can be added in the Requirements page.
| Requirements of use case |
To add requirement(s) to a use case:
| NOTE: | The Requirements page is for adding existing requirements as requirements. If you want to define a new requirement, read the next section Adding a sub-diagram. Information about how to add a requirement diagram as sub-diagram and define the requirements in the diagram is provided. Requirements are made in Diagrams page will be automatically added to the use case's requirements. |
You can make use of another diagram for elaborating a use case. The Diagrams page enables you to add and open sub-diagrams of a use case. When you select a diagram on the list on the left, you may preview it on the right if Show preview is checked.
| Diagrams of use case |
| Add a sub-diagram |
Select a sub-diagram on the list to open and click the Open button at the bottom of Diagrams page.
While the detailed testing procedure can be documented in flow of events, the testing setup and configurations can be documented in the Test Plan tab.
| Test Plan of use case |
You may add references to both internal and external artifacts, such as shapes, diagrams, files, folders and URLs for describing the use case in various views.
| References of use case |
Use Case Description was an obsolete feature removed in Visual Paradigm Suite version 4.1. We recommend users to use the flow of events tool to document the internal flow of use case rather than making use of use case description. But for the old version users, they can still activate the Description pane to access the saved data.
| Obsolete use case description |
You can convert the obsolete use case details to flow of events by clicking on the Convert button at the bottom right corner.
| Convert use case description |
| 1. Creating use case diagram | Table of Contents | 3. Documenting flow of events |
Technical Support
Sales Support
