Technical Support
Sales Support
A use case can be elaborated by using sequence diagram and activity diagram to model its interactions and activity flows respectively.
You can document the communication between user and system through the use of flow of events. You can then visualize the communication in sequence diagram through synchronizing flow of events to sequence diagram.
| Open use case details |
| Open flow of events editor |
| Generate sequence diagram from flow of events |
When you have made some changes on flow of events, you can update the changes to sequence diagram accordingly. Right click on the flow of events editor and select synchronize to the name of sequence diagram from the pop-up menu.
| Update changes from flow of events to sequence diagram |
You can document the events of a use case through the use of flow of events. You can then visualize the events in activity diagram through synchronizing flow of events to activity diagram.
| Generate activity diagram from flow of events |
If you want to return to the flow of events, right click on a target action in activity diagram and select Related Elements > Open Flow of event from the popup menu.
| Open flow of events from activity diagram |
When you have made some changes on flow of events, you can update the changes to activity diagram accordingly. Right click on the flow of events editor and select synchronize to the name of activity diagram from the pop-up menu.
| Update changes from flow of events to activity diagram |
| 3. Documenting flow of events | Table of Contents | 5. Actor grid |
Technical Support
Sales Support
