Technical Support
Sales Support
Actors grid is a table with actors listed in it. It lets you to access all actors in a project or diagram, check their related use cases, lookup and create actors.
Click on UML on toolbar and select Actor Grid from the drop down menu.
| Open Actor Grid |
| The actors grid |
| The fields in actors grid |
Click on the name of use case in the Related use case cell of the actor that we want to access its related use case.
| Access use case from actor |
| Create an actor in grid |
| Name actor |
| NOTE: | The actors created in actors grid are automatically put under the Actors model. You may move to another model through dragging and dropping in Model Explorer. |
You can form a diagram with actor, or show it in an existing diagram by visualizing it in actors grid. To visualize an actor:
| Select an actor to visualize |
| Create Visualize... |
| Name a new diagram |
| Select an existing use case diagram to visualize the actor |
By filtering actors, actors that do not match the required naming convention are filtered. To filter, enter the name of actor, or part of its name at the top right of grid. You can make use of the asterisk (*) character to represent any character(s).
| Filter actor by name |
To find out actors that match specific naming or documentation pattern:
| Find an actor |
| The matched actors are highlighted |
| 4. Elaborating use case | Table of Contents | 6. Use case grid |
Technical Support
Sales Support
