Technical Support
Sales Support
Use case grid is a table with use cases listed in it. It lets you to access all use cases in a project or diagram, check their related actors, lookup and create use case.
Click on UML on toolbar and select Use Case Grid from the drop down menu.
| Open Use Case Grid |
| The use cases grid |
| The fields in use cases grid |
Click on the name of actor in the Primary actors/Supporting actors cell of the use case that we want to access its related actor.
| Access actor from use case |
| Create a use case in grid |
| Name use case |
| NOTE: | The use cases created in use cases grid are automatically put under the Use Cases model. You may move to another model through dragging and dropping in Model Explorer. |
To browse for the details of a use case, select the use case in grid and click on the
button. This opens its use case details.
You can form a diagram with use case, or show it in an existing diagram by visualizing it in use cases grid. To visualize a use case:
| Select a use case to visualize |
| Click Visualize... |
| Name a new diagram |
| Select an existing use case diagram to visualize the use case |
By filtering use cases, use cases that do not match the required naming convention are filtered. To filter, enter the name of use case, or part of its name at the top right of grid. You can make use of the asterisk (*) character to represent any character(s).
| Filter use case by name |
To find out use cases that match specific naming/ alias/ label/ documentation pattern:
| Find a use case |
| The matched use cases are highlighted |
| 5. Actor grid | Table of Contents | Chapter 2. Class diagram |
Technical Support
Sales Support
