Creating sequence diagram
A sequence diagram is used primarily to show the interactions between objects that are represented as lifelines in a sequential order.
Creating a sequence diagram
  • Click on UML on toolbar and select Sequence Diagram from the drop down menu.
  • Right click on Sequence Diagram in Diagram Navigator and select New Sequence Diagram from the popup menu.
  • Select File > New Diagram > UML Diagrams > Sequence Diagram from the main menu.
Create sequence diagram
Enter name for the newly created sequence diagram in the text field of pop-up box on the top left corner.
Enter name for sequence diagram
Creating actor
To create actor, click Actor on the diagram toolbar and then click on the diagram.
Create actor
Create actor
Creating lifeline
To create lifeline, you can click LifeLine on the diagram toolbar and then click on the diagram.
Alternatively, a much quicker and more efficient way is to use the resource-centric interface. Click on the Message -> LifeLine resource beside an actor/lifeline and drag.
Create lifeline
Create lifeline
Move the mouse to empty space of the diagram and then release the mouse button. A new lifeline will be created and connected to the actor/lifeline with a message.
Lifeline and message created
Auto extending activation
When create message between lifelines/actors, activation will be automatically extended.
Auto extend activation
Using sweeper and magnet to manage sequence diagram
Sweeper helps you to move shapes aside to make room for new shapes or connectors. To use sweeper, click Sweeper on the diagram toolbar (under the Tools category).
Click Sweeper
Click Sweeper
Click on empty space of the diagram and drag towards top, right, bottom or left. Shapes affected will be swept to the direction you dragged.
The picture below shows the actor Inspector Assistant is being swept towards right, thus new room is made for new lifelines.
Sweep towards right
Sweep towards right
The picture below shows the message specify visit time is being swept downwards, thus new room is made for new messages.
Sweep downwards
Sweep downwards
You can also use magnet to pull shapes together. To use magnet, click Magnet on the diagram toolbar (under the Tools category).
Click Magnet
Click Magnet
Click on empty space of the diagram and drag towards top, right, bottom or left. Shapes affected will be pulled to the direction you dragged.
The picture below shows when drag the magnet upwards, shapes below dragged position are pulled upwards.
Pull shapes upwards using magnet
Creating combined fragment for messages
To create combined fragment to cover messages, select the messages, right-click on the selection and select Create Combined Fragment, and then select a combined fragment type (e.g. loop) from the popup menu.
Create combined fragment for messages
A combined fragment of selected type will be created to cover the messages.
Combined fragment created
Adding/removing covered lifelines
After you've created a combined fragment on the messages, you can add or remove the covered lifelines.
  1. Move the mouse over the combined fragment and select Add/Remove Covered Lifeline... from the pop-up menu.
    Add/Remove covered lifelines
  2. In the Add/Remove Covered Lifelines dialog box, check the lifeline(s) you want to cover or uncheck the lifeline(s) you don't want to cover. Click OK button.
    Check Inspector Assistant
    As a result, the area of covered lifelines is extended or narrowed down according to your selection.
    The area of covered lifelines is extended
Managing Operands
After you've created a combined fragment on the messages, you can also add or remove operand(s).
  1. Move the mouse over the combined fragment and select Operand > Manage Operands... from the pop-up menu.
    Manage operands
    Manage operands
  2. To remove an operand, select the target operand from Operands and click Remove button. Click OK button.
    Remove Operand2
    Remove Operand2
    Otherwise, click Add button to add a new operand and then name it. Click OK button.
Developing sequence diagram with quick editor or keyboard shortcuts
In sequence diagram, an editor appears at the bottom of diagram by default, which enables you to construct sequence diagram with the buttons there. The shortcut keys assigned to the buttons provide a way to construct diagram through keyboard. Besides constructing diagram, you can also access diagram elements listing in the editor.
The quick editor
The quick editor
Editing lifelines
There are two panes, Lifelines and Messages. The Lifelines pane enables you to create different kinds of actors and lifelines.
Lifelines pane in quick editor
Button
Shortcut
Description
Alt-Shift-A To create an actor.
Alt-Shift-L To create a general lifeline.
Alt-Shift-E To create an <<entity>> lifeline.
Alt-Shift-C To create a <<control>> lifeline.
Alt-Shift-B To create a <<boundary>> lifeline.
Alt-Shift-O To open the specification of the element chosen in quick editor.
Ctrl-Del To delete the element chosen in quick editor.
Ctrl-L To link with the diagram, which cause the diagram element to be selected when selecting an element in editor, and vice versa.
Buttons in Lifelines pane
Editing messages
The Messages pane enables you to connect lifelines with various kinds of messages.
Messages pane in quick editor
Button Shortcut Description
Alt-Shift-M To create a message that connects actors/lifelines in diagram.
Alt-Shift-D To create a duration message that connects actors/lifelines in diagram.
Alt-Shift-C To create a create message that connects actors/lifelines in diagram.
Alt-Shift-S To create a self message on an actor/lifeline in diagram.
Alt-Shift-R To create a recursive message on an actor/lifeline in diagram.
Alt-Shift-F To create a found message that connects to an actor/lifeline.
Alt-Shift-L To create a lost message from an actor/lifeline.
Alt-Shift-E To create a reentrant message that connects actors/lifelines in diagram.
Ctrl-Shift-Up To swap the chosen message with the one above.
Ctrl-Shift-Down To swap the chosen message with the one below.
Ctrl-R To revert the direction of chosen message.
Alt-Shift-O To open the specification of the message chosen in quick editor.
Ctrl-Del To delete the message chosen in quick editor.
Ctrl-L To link with the diagram, which cause the message to be selected when selecting a message in editor, and vice versa.
Buttons in Messages pane
Expanding and collapsing the editor
To hide the editor, click on the down arrow button that appears at the bar on top of the quick editor. To expand, click on the up arrow button.
Collapse the quick editor
Setting different ways of numbering sequence messages
You are able to set the way of numbering sequence messages either on diagram base or frame base.
Diagram-based sequence message
Right click on the diagram's background, select Sequence Number and then either Single Level or Nested Level from the pop-up menu.
Diagram-based pop-up menu
If you choose Single Level, all sequence messages will be ordered with integers on diagram base. On the other hand, if you choose Nested Level, all sequence messages will be ordered with decimal place on diagram base.
Single level
Single level
Frame-based sequence message
Right click on the diagram's background, select Sequence Number and then either Frame-based Single Level or Frame-based Nested Level from the pop-up menu.
Frame-based pop-up menu
When you set the way of numbering sequence messages on frame base, the sequence messages in frame will restart numbering sequence message since they are independent and ignore the way of numbering sequence message outside the frame.
Frame-based nested level
Chapter 3. Sequence diagram Table of Contents Chapter 4. Communication diagram
Technical Support
Sales Support
Discussion Forum
