Creating state machine diagram
State machine diagram shows flow of control from state to state within single object. It usually contains simple states, composite states, composite states, transitions, events and actions.
  • Click on UML on toolbar and select State Machine Diagram from the drop down menu.
  • Right click on State Machine Diagram in Diagram Navigator and select New State Machine Diagram from the popup menu.
  • Select File > New Diagram > UML Diagrams > State Machine Diagram from the main menu.
Create state machine diagram
Creating states and transitions
After creating a state machine diagram, an initial pseudo state appears by default. Move the mouse over it and click its resource icon Transition -> State.
Create state from initial pseudo state
Drag it to your preferred place and then release the mouse to confirm the place. As a result, a state is created and is connected to the initial pseudo state with a transition.
State and transition created
Similarly, you can use the Transition -> Final State resource to create a final state.
Create final state
Create final state
Adding region to state
To model substates of a composite state, you need to add one or more regions to it. To add a region, right click the state and select either Add Horizontal Region or Add Vertical Region from the pop-up menu.
Add region to state
Add region to state
Next, you can draw the substates inside the region.
Substates in a composite state
Modeling properties of transition
To model properties of transition such as effect and guard, right click on the target transition and select Open Specification... from the pop-up menu.
Open specification of transition
When the Transition Specification dialog box pops out, you can edit its name, effect and guard. Next, click Edit... button of the Effect property.
In Activity Specification (Effect) dialog box, change its name, and then click OK button to apply the change.
Click OK button in the Transition Specification dialog box to close it. Finally, the name and effect are shown on the transition caption.
Name and effect shown in caption of transition
Chapter 5. State machine diagram Table of Contents Chapter 6. Activity diagram
Technical Support
Sales Support
Discussion Forum
