Technical Support
Sales Support
Activity diagram is a flowchart-based diagram showing flow of control from activity to activity. It shows concurrency, branch, control flow and object flow. Swimlane, furthermore, is used for partitioning the activity states.
| Create activity diagram |
You can click either Horizontal Swimlane or Vertical Swimlane on the diagram toolbar.
| Create swimlane |
Next, click on the diagram to create it.
| Swimlane is created |
Double click at the top of partition to rename it.
| Rename partition |
To insert partition to swimlane, right click on a partition and select either Insert Partition Before or Insert Partition After from the pop-up menu. The selection depends on the location you want to insert.
| Insert partition to swimlane |
A partition is inserted.
| Partition inserted |
Click Initial Node on the diagram toolbar.
| Create initial node |
Click inside the partition to create the initial node there.
| Initial node created |
Move the mouse over the initial node, press its resource icon Control Flow -> Action.
| Create action |
Drag it to your preferred place and then release the mouse to confirm creating. An action is created and is connected to the initial node with a control flow.
| Action created |
Similarly, you can create a new action from the existing action by pressing its Control Flow -> Action resource icon.
| Create a new action from an action |
Create as much as actions you need. Finally, when you want to finish the activity diagram, press Control Flow -> Activity Final Node.
| Completed activity diagram |
A scenario is a diagram formed by the internal interaction of a sequence of action, modeled by their sub-diagrams. With scenario, you can produce a diagram which presents an overview of an execution path in activity diagram, so as to know how user and system communicate with each other in order to complete the flow.
| Edit scenario |
| Select a path for generating scenario |
| NOTE: | A path is a continuous flow of actions in the diagram, with an initial node placed at the beginning of the actions. Multiple paths are obtained by determining the existence of decision nodes within the flow. |
| Name and describe scenario |
| Select diagram for action |
| Generate scenario with specific diagram type |
Whenever the sub-diagram(s) of action(s) are updated, you can update the scenario to make it represents the latest information of interaction. To update scenario, right click on the activity diagram that have scenario produced before, select Scenarios, then the name of scenario from the popup menu.
| Chapter 6. Activity diagram | Table of Contents | Chapter 7. Component diagram |
Technical Support
Sales Support
