Technical Support
Sales Support
Deployment diagram shows the physical aspects of an object-oriented system. It also shows the configuration of run time processing nodes and artifacts.
| Create deployment diagram |
To create node model element, right click on the background of Model Explorer and select Model Element > New Model Element from the pop-up menu.
| Create model element |
In the New Model Element dialog box, type Node (Deployment) in Model element type, enter the node name in Model element name. Click OK button to confirm.
| Create node |
As a result, the Node Specification dialog box will pop out when the node is created.
| Node is created |
To create instance of node, click Instance Specification on the diagram toolbar and then click on the diagram.
| Create instance specification |
As a result, an instance specification will be created.
| Instance specification created |
To specify classifiers for an instance specification, right click on the target instance specification and select Select Classifier > Select Classifier... from the pop-up menu.
| Select classifier |
When the Instance Specification Specification dialog box pops out, the Classifiers tab is opened by default. Select the classifier(s) on the left and click Add Selected button to add them.
| Add selected classifiers |
Click OK button to close the specification dialog box. Finally, the selected classifier is assigned to the instance specification.
| Classifier is assigned |
To create link from instance specification, move the mouse over the target shape and press its resource icon Link -> Instance Specification.
| Create link |
Drag to empty space of the diagram to create a new instance specification, or drag to an existing instance specification to connect to it. Release the mouse button to create the link.
| Link created |
Similar to creating instance of node, you first create a component model element, and then create an instance specification, but in this case, you assign a component to the instance specification as classifier. After that, the instance specification will be displayed as a component.
| Instance of component |
To create dependency, click Dependency on the diagram toolbar.
| Create dependency |
Drag from the source shape, move the mouse over the target shape and then release the mouse button to create the dependency.
| Dependency created |
Continue to complete the diagram.
| Completed diagram |
| Chapter 8. Deployment diagram | Table of Contents | Chapter 9. Package diagram |
Technical Support
Sales Support
