Technical Support
Sales Support
Object diagram shows a snapshot of instances of things in class diagram. Similar to class diagram, it shows the static design of system from the real or prototypical perspective.
| Create object diagram |
To create instance specification, click Instance Specification on the diagram toolbar and then click on the diagram.
| Create instance specification |
An instance specification will be created.
| Instance specification created |
To specify classifiers for an instance specification, right-click it and select Select Classifier > Select Classifier... from the popup menu.
| Select classifier |
When the Instance Specification Specification dialog box pops out, the Classifiers tab is opened by default. Select the classifier on the left and click Add Selected button to add it.
| Add selected classifiers |
Click OK button to close the specification dialog box. The selected classifiers are assigned to the instance specification.
| Classifier assigned |
To define slots for an instance specification, right-click it and select Slots... from the pop-up menu.
| Define slots |
The Instance Specification Specification dialog box appears with the Slots tab selected. Select the features that you want to define slots on the left and click Define Slot button.
| Select features to define slots |
Select a slot in Defined slots and click Edit Values... button.
| Edit values of slot |
The Slot Specification dialog box pops out, the Values tab is opened by default. Click Add button and select Text from the pop-up menu.
| Add text value |
Enter the value when prompted. Close the specification dialog boxes to apply the changes, defined slots will be shown in the instance specification.
| Defined slots shown |
To create link from instance specification, click the Link -> Instance Specification resource beside it and drag.
| Create link |
Drag to empty space of the diagram to create a new instance specification, or drag to an existing instance specification to connect to it. Release the mouse button to create the link.
| Link created |
Continue to complete the diagram.
| Completed diagram |
| Chapter 10. Object diagram | Table of Contents | Chapter 11. Composite structure diagram |
Technical Support
Sales Support
