Technical Support
Sales Support
Timing diagram shows time, event, space and signal for real-time and distributed system.
| Create timing diagram |
To create timing frame, click Timing Frame on the diagram toolbar and then click on the diagram.
| Create timing frame |
Double click on the top left corner of the frame to rename it.
| Rename frame |
The name of a timing frame is usually preceded by the sd keyword.
| Frame renamed |
To add lifeline to frame, right click the frame and select Add Lifeline from the pop-up menu.
| Add lifeline |
Double-click on the name of the lifeline to rename it.
To add time unit to frame, right click the frame and select Add Time Unit from the pop-up menu.
| Add time unit |
Repeat the step to add as many as time units you need. Double click on a time unit to rename it.
| Rename time unit |
To add state/condition to lifeline, right click the lifeline and select Add State/Condition from the pop-up menu.
| Add state/condition |
Double click on the name of the state/condition to rename it.
Mouse over the line segment of a time instance, click and drag it.
| Drag time instance |
Release the mouse button when reached the target state/condition.
| Dragged time instance |
You can also move a group of time instances that are at the same state/condition. Mouse over the time instances and you will see a blue line above them, click and drag on the blue line.
| Move a group of time instances |
Release the mouse button when reached the target state/condition. The group of time instances is moved at once.
| Moved group of time instances |
To add time messages to frame, right-click the frame and select Edit Frame... from the pop-up menu.
| Edit frame |
In the Edit Frame dialog box, open the Time Messages tab and click Add... button.
| Add time message |
When the Add Time Message dialog box pops out, enter name and select the start lifeline, start time, end lifeline and end time for this time message. Note that as time units may be unnamed, when selecting start/end time you should check the relative position of the time unit in the list.
| Select end time of time message |
The time message is shown on the frame.
| Time message |
Duration constraint is used to show the duration limitation of a particular lifeline over a period of time.
| Edit lifeline |
| Add duration constraint |
| Duration constraint is added |
To switch to compact view mode, right-click the frame and select View Mode > Compact from the popup menu.
| Switch to compact view mode |
The frame will be shown in compact mode.
| Frame shown in compact mode |
| Chapter 12. Timing diagram | Table of Contents | Chapter 13. Interaction overview diagram |
Technical Support
Sales Support
