Creating interaction overview diagram
Interaction overview diagram is the variant of activity diagram in which a control flow with nodes represents interaction diagrams. Interaction diagrams are constructed with blocks, such as sequence, communication, interaction overview and timing diagrams. Most of the notation for interaction overview diagrams is the same as activity diagrams, for example, initial, final, decision, merge, fork and join nodes. However, interaction overview diagram introduces two new elements: interaction occurrences and interaction elements.
  • Click on UML on toolbar and select Interaction Overview Diagram from the drop down menu.
  • Right click on Interaction Overview Diagram in Diagram Navigator and select New Interaction Overview Diagram from the popup menu.
  • Select File > New Diagram > UML Diagrams > Interaction Overview Diagram from the main menu.
Create interaction overview diagram
Creating initial node
To create initial node, click Initial Node on the diagram toolbar and then click on the diagram.
Create initial node
Create initial node
An initial node is created. The caption of initial node is hidden by default. If you want to show it, right click on the diagram background and select Presentation Options > Show Shape Caption > Initial Node from the pop-up menu.
Show caption of initial node
Creating decision node
To create a decision node from an initial node, move the mouse over the initial node and press its resource icon Generic Resource.
Generic resource
Generic resource
Drag it to your preferred place and then release the mouse button. Select Control Flow -> Decision Node from the pop-up menu.
Create decision node
If you want to show the caption of decision node, right click on the diagram background and select Presentation Options > Show Shape Caption > Decision Node from the pop-up menu.
Creating interaction use
To create an interaction use, move the mouse over a shape and press its resource icon Control Flow -> Interaction Use.
Create interaction use
Drag it to your preferred place and then release the mouse button. An interaction use is created and connected to the shape you selected with a control flow.
Interaction use and control flow created
You can make the interaction use refer to a diagram by right clicking on it and select Refers to > New Sequence Diagram from the pop-up menu.
Interaction use refers to diagram
When a new sequence diagram is created, rename it.
Rename sequence diagram
When you return to the interaction overview diagram, you can see the interaction use caption shows the diagram it refers to.
Interaction use caption updated
Creating fork node
To create a fork node, move the moue over a shape and press its resource icon Control Flow -> Fork Node.
Create fork node
Create fork node
Drag it to your preferred place and then release the mouse button. A fork node is created and connected to the shape you selected with a control flow.
The fork node created is vertical by default. If you want to change it to horizontal, right click on the fork node and select Orientation > Horizontal from the pop-up menu.
Change fork node orientation
Moreover, if you want to show the caption of fork node, right click the diagram and select Presentation Options > Show Shape Caption > Fork Node from the pop-up menu.
To create an interaction, move the mouse over a shape and press its resource icon Control Flow -> Interaction.
Create interaction
Create interaction
Drag it to your preferred place and then release the mouse button. An interaction is created and connected to the shape you selected with a control flow.
A new sequence diagram is created and associated with an interaction by default. To open it, right click on the interaction and select Associated Diagram > (target diagram name).
Open associated diagram of interaction
Draw the sequence diagram.
Sequence diagram
Sequence diagram
When you return to the interaction overview diagram, you can see the interaction shows the thumbnail of the sequence diagram.
Updated diagram thumbnail in interaction
Creating join node
To create a join node, move the mouse over a shape and press its resource icon Control Flow -> Join Node.
Create join node
Create join node
Drag it to your preferred place and then release the mouse button. A join node is created and connected to the shape you selected with a control flow.
The join node created is vertical by default, to change it to horizontal, right click on the join node and select Orientation > Horizontal from the pop-up menu.
Moreover, if you want to show the caption of join node, right click the diagram background and select Presentation Options > Show Shape Caption > Join Node from the pop-up menu.
Creating activity final node
To create an activity final node, move the mouse over a shape and press its resource icon Control Flow -> Activity Final Node.
Create activity final node
Drag it to your preferred place and then release the mouse button. An activity final node is created and connected to the shape you selected with a control flow.
Activity final node and control flow created
If you want to show the caption of activity final node, right click on the diagram background and select Presentation Options > Show Shape Caption > Activity Final Node from the pop-up menu.
Continue to complete the diagram.
Completed diagram
Completed diagram
Chapter 13. Interaction overview diagram Table of Contents Part III. Enterprise architecture
Technical Support
Sales Support
Discussion Forum
