Technical Support
Sales Support
There are two types of connectors for modeling flows in a process - Sequence flow and Message flow. A sequence flow is used to connect flow objects in a process or a choreography, to show the flow. Message flow is used to show the flow of messages between separate pools/lanes. You cannot use message flow to connect flow objects within the same participant.
| Sequence and message flows can be used to connect flow objects |
As mentioned before, you can use sequence flow to connect flow objects within a participant, and use message flow to connect flow objects in separate participants. If you attempt to use a type of flow incorrectly, like to connect flow objects within participant with message flow, you will be prompt to correct your flow.
| Invalid connector is detected |
There are several actions you can perform. First, you can correct your invalid flow by changing its type, like to change from message to sequence flow. If the connector should not be there, you may select to delete it. If you really want to keep the invalid connector, choose Ignore all at the bottom of dialog box. Click OK to confirm.
| Possible actions of handling invalid connector - Correct it or delete it |
You can define a message that pass by message flow, and visualize it.
| A sample BPD with messages |
To do this:
| Create a message |
| Ways of showing message (from left to right) - Do Not Show, Associated with Message Flow, Overlapping Message Flow |
| 5. Gateway | Table of Contents | 7. Choreography task and sub-process |
Technical Support
Sales Support
