Technical Support
Sales Support
In order to simulate a business process you need to define simulation details like available and required resources, duration of tasks/sub-processes, instances of pools/lanes and inputs. All these information can be defined in simulacian control pane, which is a pane that display at the bottom of diagram, important for adjusting any settings related to simulacian. The panel will be updated base on your selection in active diagram. Besides setting simulacian details, start/pause of simulation can also be done in the panel.
To open the simulacian control panel, right click on thebackground of business process diagram that you want to simulate and select Show Simulacian Control Panel from the pop-up menu.
| Open simulacian control panel |
| NOTE: | You can open simulacian control panel only for diagram that has selected Simulacian as diagram type. To check/edit diagram type, right click on the background of business process diagram and select Diagram Type from the popup menu. |
| An overview of simulacian control panel |
| Description of simulacian control panel |
| An overview of simulacian control panel while selected pool/lane |
| Description of simulacian control panel while selected pool/lane |
| An overview of simulacian control panel while selected flow object |
| Description of simulacian control panel while selected flow objects |
| An overview of simulacian control panel while selected diagram background or showing inputs |
| Description of simulacian control panel while selected diagram background or showing inputs |
| An overview of simulacian control panel while simulating |
| Description of simulacian control panel while simulating |
| 1. What is simulacian? | Table of Contents | 3. Simulating business process |
Technical Support
Sales Support
