Cost per flow object
Sometimes, just by watching the simulacian outcome is not enough in finding out the bottleneck, especially when the diagram is large, and has many, many bottlenecks. In such cases, you can produce charts for simulacian outcome, which helps quantify resource consumption and queuing time for each flow object.
To read the charts, click Simulacian Charts in simulacian control panel.
Open simulacian charts window
Cost per flow object chart
The cost per flow object chart shows the cost each flow object consumed throughout simulation.
An overview of cost per flow object chart
No. Name Description
1 Completion
Click to show completion chart.
2 Resource Usage
Click to show resource usage chart.
3 Queue Time Click to show queen time chart.
4 Cost Per Input Click to show cost per input chart.
5 Time Cost Click to show time cost chart.
6 Auto refresh
Check to let the chart body auto update against chart settings such as time scale and selection of inputs. Uncheck to update manually by clicking Refresh.
7 Refresh
Click to update the chart body against the chart settings such as time scale and selection of inputs. This button is available only when Auto Refresh is unchecked.
8 Nodes Check or uncheck flow objects nodes to show or hide their cost per flow object in chart.
9 Chart body
The chart body.
10 Export
Click to export the opening chart to Microsoft Excel or image file.
11 OK
Click to close the simulacian charts window and go back to the diagram.
Description of cost per flow object chart
3. Queue Time Table of Contents 5. Cost per input
Technical Support
Sales Support
Discussion Forum
