Technical Support
Sales Support
Requirement diagram lets you visualize system functions as well as the ways to test the functions. It is one of the SysML diagram types. You can create your own requirement type for business specific needs. The customization part will be covered in the next page.
| Create requirement diagram |
Alternatively, select File > New Diagram > Requirements Capturing > Requirement Diagram from the main menu to create a requirement diagram.
To create a Requirement, click the Requirement button on the diagram toolbar and then click on the diagram.
| Create Requirement |
To decompose a Requirement, click the Containment -> Requirement resource and drag.
| Decompose Requirement |
Move the mouse over empty space of the diagram and then release the mouse button, a Requirement together with a Containment relationship will be created.
| Requirement and Containment created |
To inline edit the property of a Requirement (e.g. ID), double-click on the property, enter new value and press Enter to confirm.
| Inline editing Requirement properties |
You can also open specification dialog box of a Requirement to edit its properties. Click Open Specification resource of the Requirement.
| Open specification of Requirement |
The Requirement Specification dialog box shows. Edit the properties and click OK button to apply the changes.
| Requirement Specification |
To create a Test Case, click the Test Case button on the diagram toolbar and then click on the diagram.
| Create Test Case |
Click Verify -> Requirement resource of Test Case and drag.
| Link Requirement with Test Case |
Move the mouse over a Requirement and then release the mouse button, a Verify relationship will be created from the Test Case to the Requirement.
| Verify relationship created |
| Chapter 1. Requirement diagram | Table of Contents | 2. Customizing requirement types |
Technical Support
Sales Support
