Technical Support
Sales Support
Requirements grid is a table with requirements listed in it. It enables you to access all requirements in a project or diagram, look up requirements by criteria and create requirements.
Click on Requirement on toolbar and select Requirement Grid from the drop down menu.
| New Requirement Grid |
| The requirements grid |
| Overview of requirement grid |
| Name requirement |
| NOTE: | The requirements created in requirements grid are automatically put under the Requirements model. You may move to another model through dragging and dropping in Model Explorer. |
You can form a diagram with requirement, or show it in an existing diagram by visualizing it in requirements grid. To visualize a requirement:
| Select a requirement to visualize |
| Name a new diagram |
| Select an existing requirement diagram to visualize the requirement |
By filtering requirements, requirements that do not match the required naming convention are filtered. To filter, enter the name of requirement, or part of its name at the top right of grid. You can make use of the asterisk (*) character to represent any character(s).
| Filter requirement by name |
To find out requirements that match specific naming or documentation pattern:
| Enter requirement name to find |
| The matched requirements are highlighted |
| 2. Customizing requirement types | Table of Contents | Chapter 2. Textual analysis |
Technical Support
Sales Support
