Technical Support
Sales Support
Users can record and present requirements as boxes visually through requirement modeling. The name of requirements summarizes the requirement while a set of attributes defines the requirement. The default requirement box allows users to specify general attributes, such as ID, source, kind, verify method, risk and status. Moreover, you are allowed to customize your own requirement types that contain attributes related to your domain.
| Add a new requirement type in the Configure Requirements dialog box |
| Enter name for requirement type |
| Select an attribute |
| Enter name for attribute |
| NOTE: | If you select Enumeration Attribute from the drop-down menu, Edit Enumeration... button will appear. Click Edit Enumeration... button to edit it. |
| Customize color for requirement type |
| NOTE: | Click the ... button of Line if you want to customize its line property while click the ... button of Font if you want to customize its font property. |
| The customized requirement type |
| 1. Creating requirement diagram | Table of Contents | 3. Requirement grid |
Technical Support
Sales Support
