Creating CRC card diagram
Class-Responsibility Collaborator (CRC) card visualizes classes in card-like presentation. Each CRC card contains information like the description of class, its attributes and responsibility. A CRC card diagram is a holder of these cards.
  • Click on Requirement on toolbar and select CRC Card Diagram from the drop down menu.
  • Right click on CRC Card Diagram in Diagram Navigator and select New CRC Card Diagram from the popup menu.
  • Select File > New Diagram > Requirements Capturing > CRC Card Diagram from the main menu.
Create CRC card diagram
Creating CRC card
Select CRC Card from the diagram toolbar. Click on the diagram to create a CRC card. You can create multiple CRC card on a diagram by repeating this step.
Create CRC card
Create CRC card
Editing CRC card properties
All properties in a CRC card must be edited inline. To edit, double click on the desired field, update its value, and click on the diagram background to confirm editing.
Edit description
Edit description
Adding attributes
Right-click on the Attributes heading and select Add > Attribute from the popup menu.
Add attribute
Add attribute
Enter the name and description. Repeat this step until all attributes are added.
All attributes added
Adding responsibilities
Right-click on the Responsibilities heading and select Add > Responsibility from the popup menu. Like creating an attribute, enter the name and collaborator of each responsibility to show the relationship with other parties.
Add responsibility
Add responsibility
Chapter 3. CRC card diagram Table of Contents Chapter 4. User interface designer
Technical Support
Sales Support
Discussion Forum
