Technical Support
Sales Support
A scrollbar is a bar with a knob which appears at the bottom or right of a container, such as a frame. The user positions the knob in the scrollbar to determine the contents of the viewing area. The program typically adjusts the display so that the end of the scrollbar represents the end of the displayable contents, or 100% of the contents. The start of the scrollbar is the beginning of the displayable contents, or 0%. The position of the knob within those bounds then translates to the corresponding percentage of the displayable contents.
| Select Horizontal Scrollbar from diagram toolbar |
| Scrollbar is created |
A scrollbar can be oriented horizontally or vertically, which determines the contents of the viewing area when being scrolled. User can change the orientation of a scrollbar easily through the resource-centric interface. When a scrollbar is put inside a container, changing orientation will automatically dock to the bottom or the right of container. To change scrollbar orientation:
| Click Scrollbar Orientation |
| Scrollbar is switched from horizontal to vertical |
In a normal User Interface design, scrollbars, no matter horizontal or vertical, are placed at the bottom or on the right of a container component. Agilian follows this practice. When creating a scrollbar in a container component, or when moving a scrollbar into a container component, the scrollbar will be docked to the border of component automatically.
The appearance of scrollbar can be changed by editing its properties. To configure a scrollbar, right click on the scrollbar and select Open Specification... from the popup menu. The UI tab is where user can configure a scrollbar.
| Description of scrollbar properties |
| 4. Text Field | Table of Contents | 6. Combo Box |
Technical Support
Sales Support
