Technical Support
Sales Support
A Tree is a component that displays a set of hierarchical data as an outline.
| Select Tree from diagram toolbar |
| Drag diagonally to expand the Tree |
| Tree is created |
To insert columns and rows into a tree:
| Insert a node into tree |
| Insert a child node |
To remove a node in a tree, open the specification dialog box of the tree, open the UI tab, right click on the node(s) to remove and select Remove Node in the pop-up menu.
| Remove a node in tree |
To reorder nodes, open the specification dialog box of the tree, open the UI tab, select the node(s) to reorder, and click on the Move Up or Move Down button.
| Move a node in tree upwards |
The appearance of tree can be changed by editing its properties. To configure a tree, right click on the tree and select Open Specification... from the popup menu. The UI tab is where user can configure a tree.
| Description of tree properties |
| 8. Table | Table of Contents | 10. Web Label |
Technical Support
Sales Support
