Mouse gestures
A variety of shapes and model elements can be created by sketching a path directly on the diagram pane with dragging the right mouse button to form a gesture. For your convenience and quick creation, mouse gestures allow you to execute common commands and create models within all diagrams.
Drawing shapes
  1. To start using a mouse gesture, press the right mouse button and drag it until finish drawing a shape.
    Draw a clockwise rectangle
  2. When the shape is done, release the mouse. After the shape is created, the action description will be shown on top right corner of the diagram.
    Class is created
    Class is created
Creating Class member
You can learn how to create attribute and operation within the class in the following sub-sections.
Creating an attribute
  1. To create attribute, draw a line from the right to the left within the class. As a result, an attribute is created.
    Attribute is created
  2. If you draw the line until outside the class, an attribute with <<Property>> stereotype will be created.
    <<Property>> is created
Creating an operation
  1. To create operation, draw a line from the left to the right within the class, an operation with protected visibility is created.
    Operation is created
  2. If draw the line until outside the class, a public operation will be created.
    Public operation is created
Connecting shapes
  1. Draw a line from one shape to another.
    Draw a line from a shape to another
  2. After the mouse is released, a connector is created between two shapes.
    Association is created
Creating a new shape
  1. A new shape can also be created. To do so, draw a line from an existing shape to your preferred place.
    Draw a line to an empty area
  2. After the mouse is released, a pop-up menu will be shown. You can select your preferred type of connector and shape from the pop-up menu.
    Create generalization with class
  3. The two shapes with connector are created.
    Class with generalization is created
List of supported mouse gestures
General
Icon Description
Layout diagram
Open diagram specification
Connect new shape
Connect existing shape
Close Diagram
Thumbnail view
The description of general mouse gestures
Activity diagram
Icon Description
Action
Activity
Decision Node
Initial Node/Finial Node (If there is no Initial Node, an Initial Node will be created. Else if there is no Final Node, a Final Node will be created.)
The description of mouse gestures for activity diagram
Activity diagram (UML 1.x)
Icon Description
Action State
Sub-Activity
Swimlane
Horizontal Synchronization Bar
Vertical Synchronization Bar
Initial State/Final State (If there is no Initial State, an Initial State will be created. Else if there is no Final State, a Final State will be created.)
The description of mouse gestures for activity diagram (UML 1.x)
Business process diagram
Icon Description
Sub-Process
Pool/Task
Horizontal Lane
Vertical Lane
The description of mouse gestures for business process diagram
Class diagram
Icon
Description
Sync. to ERD
Class
Package
Add attribute (Add an attribute to class. If mouse released outside the class, getter and setter property will be set to true.)
Add operation (Add an operation to class. If mouse released inside the class, visibility will be protected, otherwise it will be public.)
The description of mouse gestures for class diagram
Communication diagram
Icon Description
Sync. To Sequence Diagram
Lifeline
Actor
Package
The description of mouse gestures for communication diagram
Component diagram
Icon Description
Component
Instance Specification
Package
The description of mouse gestures for component diagram
Composite structure diagram
Icon Description
Class
Interface
Collaboration
Collaboration Use
The description of mouse gestures for composite structure diagram
Data flow diagram
Icon Description
Process
External Entity
Data Store
The description of mouse gestures for data flow diagram
Deployment diagram
Icon Description
Node
Component
Package
The description of mouse gesture for deployment diagram
EJB diagram
Icon Description
Entity Bean
Message-Driven Bean
Session Bean
Package
The description of mouse gestures for EJB diagram
Entity relationship diagram
Icon Description
Sync. to Class Diagram
Entity
Add column
The description of mouse gestures for ERD
Interaction overview diagram
Icon Description
Interaction
Decision Node
Initial Node/Final Node (If there is no Initial Node, an Initial Node will be created. Else if there is no Final Node, a Final Node will be created.)
The description of mouse gestures for interaction overview diagram
Mind mapping diagram
Icon Description
Node
The description of mouse gesture for mind mapping diagram
Object diagram
Icon Description
Class
Package
The description of mouse gestures for object diagram
ORM diagram
Icon Description
Sync. Classes -> Entities
Sync. Entities -> Classes
Class
Entity
Package
The description of mouse gestures for ORM diagram
Overview diagram
Icon Description
Diagram Overview
The description of mouse gesture for overview diagram
Package diagram
Icon Description
Package
The description of mouse gesture for package diagram
Sequence diagram
Icon Description
Sync. to Communication Diagram
Lifeline
Actor
Alt
Loop
The description of mouse gestures for sequence diagram
State machine diagram
Icon Description
State
Submachine State
Initial Node/Final Node (If there is no Initial State, an Initial State will be created. Else if there is no Final State, a Final State will be created.)
The description of mouse gestures for state machine diagram
State machine diagram (UML 1.x)
Icon Description
State
Concurrent State
Submachine State
The description of mouse gestures for state machine diagram (UML 1.x)
Timing diagram
Icon Description
Frame
The description of mouse gesture for timing diagram
Use case diagram
Icon Description
Use Case
Actor
Package
The description of mouse gestures for use case diagram
Related Resources
The following resources may help you learn more about the topic discussed in this page.
1. Sweeper and Magnet Table of Contents 3. Jumping to shape
Technical Support
Sales Support
Discussion Forum
