Technical Support
Sales Support
If you have ever experienced how hard it is to deal with a number of shapes, try the application of multi-layers. In Agilian, you can manage different shapes efficiently by making using of multi-layers. The function of layer assists you in assigning different shapes into different layers, hiding unnecessary shapes, locking shapes and selecting shapes in shortcut.
| Select Layers... from the pop-up menu |
| Create a new layer in Diagram Layers dialog box |
| New layer will be an active layer |
The existing shapes are kept in default layer. However, both existing shapes and the newly created shapes can be sent to a new layer.
Create a new layer by following the steps of previous section. Right click on a shape and select Layers, and then select the new layer you create in advance.
| Send the shape to a new layer |
As a result, the shape you selected will be sent to the new layer.
You can make a layer invisible on diagram through Diagram Layers dialog box. To do so, uncheck Visible of your target layer that you want to be hidden on diagram.
| Shapes on the layers are invisible on diagram |
In Diagram Layers dialog box, check Locked of your target layer to make all shapes in that layer immovable and non-editable while uncheck Locked to make them movable and editable.
| Shapes on the selected layer are locked |
You can also select all shapes of the selected layer. To do so, click Select shapes in selected layers button in Diagram Layers dialog box.
| Shapes of the layer are selected on diagram |
| 5. Show/hide Diagram Elements | Table of Contents | 7. Making Shape Non-selectable |
Technical Support
Sales Support
