Technical Support
Sales Support
Agilian enables you to record important ideas during a meeting through a note-taking feature called "Brainstorm". During the meeting, you pay attention to what the participants say and create note (shapes) in a corkboard -like diagram to record the key points. After the meeting, you may make use of the notes collected to help you construct the model. To optimize the process, Agilian supports a realize function to transform notes into model elements.
| Producing a task from a note |
To realize a note:
| Select note type |
If you have selected a tag for a note and you want to change it, click on any tag at bottom left of note shape and select Type > [New Tag] from the popup menu. This will clear the previously select tag and apply the newly selected one. Note that once a tag has been realized, you cannot change it to another type anymore.
You may add multiple tags to a note and realize multiple model elements from different tags (one model element per tag). To add another tag, click on any previously added tag at bottom left of note shape and select Add > [New Type] from the popup menu.
If you think that a note tag is no longer suitable for the note, you may delete it. To delete a tag, click on the tag you want delete from note and select Delete from the popup menu. Note that if the tag has been realized, deleting the tag would not delete the realized model element. And if you add the tag again, the realization relationship will be maintained.
| 1. Using Brainstorm | Table of Contents | Part XII. Impact analysis |
Technical Support
Sales Support
