Moving diagram to model
If you haven't organized project structure with model previously, but want to do it at this stage, you can move a diagram from root into a model, or transfer a diagram from one model to another.
To move diagram from one model to another:
Right click on the target model in Model Explorer and select Diagram > Add Existing Diagram... from the pop-up menu.
Add existing diagram
When Add Sub Diagrams dialog box pops out, check the diagram(s) you want to move and then click OK button to proceed.
Check a diagram in Add Sub Diagrams dialog box
As a result, the selected diagram(s) will be moved to the target model.
NOTE: If you move a diagram which has the master view of model element(s), the model element(s) will be moved together with the diagram to the new model.
Related Resources
The following resources may help you learn more about the topic discussed in this page.
2. Creating diagram under model Table of Contents Chapter 2. Animacian
Technical Support
Sales Support
Discussion Forum
