Reading model - Model/diagram element
<MetaModelElement>
Description
<MetaModelElement> is a construct which enables you to retrieve a model element from another model element.
Attributes
Name Description/Usage Required?
modelProperty : string The name of property to query from model element, which should result in returning a model element from the given model element.
Optional
Supported attributes for <MetaModelElement>
Sample template fragment
<Template>
    <TemplateInformationHeader name = "Tagged values" description = "/" type = "text" default = "false"/>
    <ElementBaseInitiationBlock>
        <MetaModelElement modelProperty = "taggedValues">
            <IterationBlock>
                <StringPropertyText propertyText = "name"/>
            </ IterationBlock >
        </MetaModelElement>
    </ElementBaseInitiationBlock>
</Template>
<FromEnd>
Description
<FromEnd> is a construct for retrieving the from-side of a relationship. Here are some of the key points you need to know when using <FromEnd> in your template:
  • The from-end of relationship is determined by the side a connector (shape) begins with. It has nothing related to the semantic or definition of notation. Take generalization as example, the from-side is the side with arrow head (unless you have configured the beginning of generalization in Options window).
  • When you try to retrieve the from-end of an association, you are retrieving the connected element (e.g. a class, a use case) instead of a role. If you need to retrieve a role, use <ForEachRelationshipEnd>
<Template>
    <TemplateInformationHeader name = "Associations and Generalizations" description = "/" type = "text" default = "false"/>
        <!-- Print from ends of associations -->
        <ForEachRelationshipEnd type = "AssociationEnd" endPointer = "self">
            <RelationshipEndEndRelationship>
                <FromEnd>
                </FromEnd>
            </RelationshipEndEndRelationship>
        </ForEachRelationshipEnd>
        <!-- Print from ends of generalizations -->
        <ForEachSimpleRelationship type = "Generalization" direction = "all">
            <FromEnd>
            </FromEnd>
</Template>
<ToEnd>
Description
<ToEnd> is a construct for retrieving the to-side of a relationship. Here are some of the key points you need to know when using <ToEnd> in your template:
  • The to-end of relationship is determined by the side a connector (shape) begins with. It has nothing related to the semantic or definition of notation. Take generalization as example, the to-side is the side without arrow head (unless you have configured the beginning of generalization in Options window).
  • When you try to retrieve the to-end of an association, you are retrieving the connected element (e.g. a class, a use case) instead of a role. If you need to retrieve a role, use <ForEachRelationshipEnd> to retrieve the association ends of an elements. The association ends returned is then the roles.
<Template>
        <!-- Print to ends of associations -->
                <ToEnd>
                </ToEnd>
        <!-- Print to ends of generalizations -->
            <ToEnd>
            </ToEnd>
</Template>
Description
<RelationshipEndEndRelationship> is a construct for retrieving relationship from a relationship end (e.g. association end). Note that <RelationshipEndEndRelationship> has no effect with <FromEnd> and <ToEnd>.
<Template>
    <TemplateInformationHeader name = "Associations" description = "/" type = "text" default = "false"/>
                <ToEnd>
                </ToEnd>
</Template>
<RelationshipEndOppositeEnd>
Description
<RelationshipEndOppositeEnd> is a construct for retrieving the opposite end of a relationship end (e.g. association end). Note that <RelationshipEndOppositeEnd> has no effect with <FromEnd> and <ToEnd>.
<Template>
        <ForEachRelationshipEnd type = "Print myself" endPointer = "self">
                <MetaModelElement property="EndModelElement">
                </ MetaModelElement>
            </RelationshipEndOppositeEnd>
</Template>
<ParentModel>
Description
<ParentModel> is a construct for retrieving the parent model element that contains a model element. For example, retrieve the package of a class.
Attributes
modelProperty : string The type of parent model element you want the model element to be/not to be contained by.
Optional
Supported attributes for <ParentModel>
<Template>
    <TemplateInformationHeader name = "Parent" description = "/" type = "text" default = "false"/>
        <ParentModel>
        </ParentModel>
</Template>
<DiagramProperty>
Description
<DiagramProperty> is a construct for retrieving a diagram from property. For example, retrieve embedded process diagram of a BPMN sub-process. Note that <DiagramProperty> is not for retrieving sub-diagrams. If you want to retrieve sub-diagrams, use <ForEachSubDiagram> instead.
Attributes
property : string The name of diagram property to retrieve from model element.
Required
Supported attributes for <DiagramProperty>
<Template>
    <TemplateInformationHeader name = "Diagram name of analysis diagram" description = "/" type = "text" default = "false"/>
    <DiagramBaseInitiationBlock>
        <IterationBlock elementType="AnalysisDiagramNode">
            <DiagramProperty property="analysisDiagramId">
                <StringPropertyText property="name"/>
            </DiagramProperty>
        </IterationBlock>
    </DiagramBaseInitiationBlock>
</Template>
<OwnerDiagram>
Description
<OwnerDiagram> is a construct that enables you to retrieve the diagram where a diagram element exists.
<Template>
    <TemplateInformationHeader name = "Diagram name of analysis diagram node" description = "/" type = "text" default = "false"/>
        <IterationBlock elementType="AnalysisViewNode">
            <DiagramElementProperty property="analysisViewId">
                <OwnerDiagram>
                </OwnerDiagram>
            </ DiagramElementProperty >
        </IterationBlock>
</Template>
<ElementImage>
Description
<ElementImage> is a construct for printing an image of diagram or diagram element, or icon for model type.
Attributes
imageType : string = icon
{diagram | icon}
Specify the type of image.
diagram – image for diagram/diagram element
icon – icon for model type
Optional
imageFormat = png
{png | jpg | wmf}
The image format (png/jpg/wmf) of the image to present. Optional
alignment = left
{left | center | right}
The position of image – left/center/right. Optional
width : integer Restrict the image to specific width. Optional
height : integer Restrict the image to specific height. Optional
maxWidth : integer Set the maximum width of image. Optional
maxHeight : integer Set the maximum height of image. Optional
landscape : boolean = false Adjust the orientation of image. True for landscape. False for portrait. Optional
Supported attributes for <ElementImage>
<Template>
    <TemplateInformationHeader name = "Class diagrams in project" description = "/" type = "text" default = "false"/>
    <ProjectBaseInitiationBlock>
        <ForEachDiagram diagramType="ClassDiagram">
            <ElementImage imageType="diagram"/>
        </ForEachDiagram>
    </ProjectBaseInitiationBlock>
</Template>
Related Resources
The following resources may help you learn more about the topic discussed in this page.
5. Reading model - Conditional checking Table of Contents 7. Text and break
Technical Support
Sales Support
Discussion Forum
