Importing Telelogic System Architect
  1. Save your Telelogic System Architect drawing:
    A Telelogic System Architect drawing
  2. To import a Telelogic System Architect project into Agilian, select File > Import > Telelogic System Architect... from the main menu.
  3. Specify the file path of the Telelogic System Architect project.
    Specifying Telelogic System Architect path
    No. Name Description
    1 File path The path of Telelogic System Architect .xml file to be imported.
    2 Import Color and Font By selecting this option, colors and fonts of the shapes to be imported will remain unchanged. Otherwise, Visual Paradigm's default settings will be applied.
    3 Auto Fit Size By selecting this option, shapes' size will be optimized to their possible minimum size. Otherwise, the original size of the imported shapes will remain unchanged.
    4 OK Click OK to proceed with importing Telelogic System Architect.
    5 Cancel Click Cancel to discard importing XML.
    Description of Import Telelogic System Architect dialog box
  4. Click OK to start importing. When import is completed, the message pane will popup, with a notification appear in it. The drawings can then be accessible in the Diagram Navigator. You can then double click on the diagram node to open the diagram.
    Diagram Navigator listing the imported diagram(s)
Related Resources
The following resources may help you learn more about the topic discussed in this page.
1. Importing Telelogic Rhapsody Project Table of Contents Chapter 10. Importing NetBeans 6.x UML diagrams
Technical Support
Sales Support
Discussion Forum
