Technical Support
Sales Support
Checkout project is a process that you download a managed project from repository to your computer and start working with. Team members should log into the Subversion in Agilian, then checkout their completed projects. Open project is to open the downloaded project in Agilian.
After entering Agilian, select Teamwork > Open Teamwork Client... from the main menu.
When the Manage Project dialog box pops out, click OK button when no other team member has been checkout any project before. You may select a specific project when other team members have been checkout out projects before.
When the Teamwork Client dialog box pops out, click Import Project to Repository button.
| Click Import Project to Repository button |
In Import Project dialog box, check an option in Project file. Check Create new project if you want to checkout a new project while check Import existing project if you want to checkout the existing project in your computer.
| Import Project dialog box |
| NOTE: | If you have an active project, the option of Currently opened project will be available. |
After the project has been checked out, click Open Project button.
| The Teamwork Client dialog box |
After that, the project has been downloaded from the server to your computer and you can start working on it.
| 2. The Teamwork Client | Table of Contents | 4. Commit |
Technical Support
Sales Support
