Tagging
Tag refers to a named version of your work at a point of time in the trunk. The best application of a tag is to create it for every major release or milestone. Note that you can neither merge a tag to the trunk nor commit it to the server.
To create a tag:
  1. In Agilian, select Teamwork > Tag... from the main menu.
  2. In Create Tag dialog box, enter the name of the tag. Select an option for Create copy in repository from. Check HEAD revision in the repository if you want to create a tag from the latest revision of trunk while check Specific revision in the repository if you want to create a tag from a specific revision. Click OK button to proceed.
6. Branching Table of Contents 8. Revert Local Modification
Technical Support
Sales Support
Discussion Forum
