Technical Support
Sales Support
Record and related terminologies under specific business domain by using fact diagram. In a fact diagram, terms are visualized as rectangular blocks. You can link terms up with connectors, and specify the kind of relationship in between. A fact diagram is closely related to business rules. It helps you identify the rules by studying the relationship between terms.
| A sample fact diagram |
To create a fact diagram, right click on Fact Diagram in Diagram Navigator and select New Fact Diagram from the popup menu.
| To create a fact diagram through Diagram Navigator |
| A list of supported notations in fact diagram |
When a fact type involves more than two terms, we call it a n-ary fact type. For example, fact type worded "helpdesk answer customer's enquiry" involves three terms helpdesk, answer and enquiry. If you have already created a fact model that involves two terms, and now want to add an additional one, you need to split a fact type, and connect the split fact type with the new term.
| Split a binary fact |
| To connect term with fact type |
| Term is connected with fact type |
| Chapter 3. Fact diagram | Table of Contents | Part IV. Data modeling |
Technical Support
Sales Support
