Shape Options
Option Name
Description
Initial Shape Size When Set to Display Image
  • Fit shape to image - Resize the image placeholder to fit the selected image
  • Fit image to shape - (default) Resize the image to fit into the image placeholder
Add Covered Shapes as Children After Resize
  • Yes - Automatic contain the covered shapes after resizing a container to cover shapes
  • No - Do not contain covered shapes after resizing a container to cover shapes
  • Prompt - (default) Ask if you want to contain covered shapes after resizing a container to cover shapes
No View Model as Master View
When you try to create a shape from existing model element, like to drag and drop model element from Model Explorer to diagram, and if the new shape is the only view of the model element, you can control whether to set the shape to be master view or not.
  • Yes - Set the created shape to be master view
  • No - Do not set the created shape to be master view
  • Prompt - (default) Ask if you want to set the created shape to be master view
Show Added Member in Other View
When you try to create a new member, like a column of an entity, on a shape, and if there is another view of the model element, you can set whether to show the member on other view as well.
  • Yes - Show the member on other view(s)
  • No - Do not show the member on other view(s)
  • Prompt - (default) Ask if you want to show the member on other view(s)
Auto Expand Parent When Moving Child Determines whether to expand the parent when moving the shape around the parent's border.
Create new line key
  • <Ctrl> + <Enter> - Press Ctrl-Enter to create a new line when inline editing
  • <Alt> + <Enter> - (default) Press Alt-Enter to create a new line when inline editing
  • <Enter> - Press Enter to create a new line when inline editing
Show unlimited level in preview shape (May slower the diagram display) (default false) Determines whether a diagram overview will show contents for all nested diagrams.
Show rich text content in preview shape (default false) Determines whether diagram overview will show rich text content.
Name completion (Classes, Entities and Requirements) (default true) When creating a class/ requirement/ an entity, you can select an existing class/requirement/entity from a list so that a view of the selected class/requirement/entity can be created. You can enable or disable the popup of such list.
Resize shape when add member (default true) For shapes that have member, like class and entitiy, when you add a member, it will or will not resize the owner against the length of member, base on this option.
Auto resize parent when resizing child (default true) When you resize a shape that makes it touches the boundary of parent, this option determines whether the parent will be expanded accordingly.
Shape Options details
3. Model Generation Table of Contents 5. Connector
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
