Connector Options
Option Name
Description
Font Default font settings for connector caption.
Connector Style
  • Rectilinear - Set the default connector style to be rectilinear
  • Round Rectilinear - Set the default connector style to be round rectilinear
  • Oblique - (default) Set the default connector style to be oblique
  • Round Oblique - Set the default connector style to be round oblique
  • Curve - Set the default connector style to be curve
Connection Point Style
  • Round the shape - (default) Set the connector end to attach the round the shape
  • Follow center - Set the connector end to point to the center of attached shapes
Line Jumps
  • Off - (default) Disable line jump
  • Arc - Show connectors' intersections as an arcs
  • Gap - Show connectors' intersections as a gaps
  • Square - Show connectors' intersections as a squares
Line jump size
  • Normal
  • Large
  • Extra large
Caption orientation
  • Horizontal only - Enforce connector caption to appear horizontally regardless of connector angle
  • Horizontal or Vertical only - Enforce connector caption to appear either horizontally or vertically, depending on the connector angle
  • Follow Connector Angle - Enforce connector caption to appear an the same horizontal level as the connector
  • Follow Connector Angle and Keep Text Upright - Enforce connector caption to appear an the same horizontal level as the connector, but keep the text upright
Foreground Foreground color of connector.
Background Background color of connector.
Paint connector through label (default true) Captions' background will become transparent so that connectors can show completely without having part of it covered by opaque caption.
Connector Options details
4. Shape Table of Contents 6. Business Process
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
