Technical Support
Sales Support
BP-VA can be launched through accessing the Start menu.
| Start BP-VA via Start menu |
For Linux users, you can start BP-VA through the shortcuts in desktop, created by the installer.
If you are a floating license client, and if your host is IP-4 enabled, you need to start BP-VA with a startup script in order to connect to the server. Here are the steps:
| Editing the start up script |
A workspace is a directory used to store all settings, user interface perspectives and other preferences defined for the working environment (settings can be configured via Tools > Options... in BP-VA). A workspace also stores all the teamwork login information and local copies of teamwork projects. In the case of switching computers, you simply need to copy the whole workspace directory to the new computer and specify the new workspace when starting BP-VA. All your teamwork information and settings will then be transferred to the new computer.
The Workspace Launcher appear when running BP-VA.
| Workspace Launcher |
Specify the workspace folder.
If you do not want this dialog box to appear again, check Use this as the default and do not ask again. This will cause BP-VA to open the specified workspace folder automatically the next time.
If you already have an existing workspace, you can import the settings from there by clicking Import Workspace....
Click OK to continue.
| Chapter 3. Getting started | Table of Contents | 2. Interface overview |
Technical Support
Sales Support
