Dockable user interface
BP-VA adapts a dockable User Interface which allows you to drag UI components around to customize your favorite working environment. You can save the environment as a perspective which you can reopen later. It allows you to use different perspectives for different purposes.
Using the dockable user interface
The dockable User Interface is composed of a number of windows called dockable frames. A dockable frame may be standalone (floating) or docked into another container (split pane/ tab pane).
You can press on its title bar of a dockable frame or press on a tab to drag it to your preferred place.
Drag the frame and dock it to elsewhere
You will notice a grey outline appears while you are dragging a tab or the whole frame. This outline helps you to set the location for docking the dockable frame/tab.
Docking a dockable frame to elsewhere
By dragging out a dockable frame/tab, and move the cursor to certain position, the frame/tab will be repositioned accordingly.
If you drag the dockable frame/tab and release it over another container, the grey outline will change its shape to fit into the dockable area for the container. If you release the frame/tab, it will be docked into the underlying container and also removed from its original container.
A frame docked to the right of application screen
You also can drag a frame/tab out to be a floating window.
You can also drag a frame/tab and dock it into another tab pane. You will see the outline changed to a tab shape if you drag over a tab pane.
A frame docked to another frame
Auto-hiding a dockable frame
A dockable frame can be set to "auto hide" that means it will automatically fold when it isn't in active. To set a dockable frame to "auto hide", click on the Toggle auto-hide button on the top right corner of the frame (it is represented by a pin icon, refer to the figure below)
Hide Diagram Navigator automatically
2. Toolbar Table of Contents 4. Diagram navigator
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
