Technical Support
Sales Support
It would be much more efficient to make use of model explorer for your middle to large scale project which has considerable numbers of diagrams and model elements, rather than using diagram navigator.
| The Model Explorer |
| The description of icons on Model Explorer |
The model explorer lists all the model elements in the project.
| The pop-up menu of model explorer |
| The description of icons on model explorer |
| The pop-up menu of project node |
| The description of pop-up menu of project node |
Model Explorer is opened by default. To close it, press the X button at the top right corner. On the other hand, it can be opened by selecting View > Panes > Model Explorer from the main menu.
A model is a package that can store model elements and diagrams. Users are recommended to structure project by using model in order to maintain a clear structure for accessing project data and improve the application performance.
Right click on the project node in Model Explorer and select Model from the pop-up menu. You can either create a custom model by selecting New Model..., or create a pre-defined model by selecting it in the list.
| Select New Model in pop-up menu |
A model element is created when you create a shape on a diagram. If you want to create a model element without visualizing it, you can create it through the Model Explorer.
To create a model element, right click on the root node, select New Model Element... from the pop-up menu. You can select the model element type and enter its name simultaneously in the New Model Element dialog box.
| Select New Model Element in pop-up menu |
In model explorer, model elements are listed under project node(s). You can sort model elements by their names, by their types (e.g. use case, package, etc.) or without sorting.
To sort by name, click Sort by Name button. The elements will be listed by name, in alphabetical order.
| Sort model elements by name |
To sort by type, click Sort by Type button. As a result, the elements will be listed by type. To arrange model elements without sorting, click No sorting.
Select the model element(s) you want to reorder. If there are multiple model elements you want to select, just click one while pressing Ctrl button and make the other selections.
Click Move Selected Model Element Up button to move the selection upwards, or Move Selected Model Element Down button to move the selection downwards.
| NOTE: | This option only works within the same model element type when there are multiple model elements. |
You can choose which model elements you want to be displayed or not on the model explorer.
Right click on the model explorer's background and select Filter Model Element. In Model Element Filtering Dialog, check the types of model element(s) you want to be displayed. Otherwise, uncheck the one you don't want to be displayed.
| Model Element Filtering Dialog |
| NOTE: | Instead of displaying all types of model elements, checking Display model element types in-use to display the types of model elements used in the project. |
If it is the case that the name of model elements is in multi-line, the character ¶ will be revealed.
When Show Carriage Return Character is selected, line break will be shown.
| Show Carriage Return Character is selected |
When deselected, the character ¶ is hidden.
If you want to hide it, right click on the model explorer's background and uncheck Show Carriage Return Character from the pop-up menu. As a result, the character will automatically be unshown.
BP-VA's team collaboration support enables your team members work together on project(s).
To connect to server and perform related activities, right click on the model explorer's background, select Teamwork and an option for performing from the pop-up menu.
| Perform teamwork |
| 4. Diagram navigator | Table of Contents | 6. Logical view |
Technical Support
Sales Support
