Documentation pane
Documentation pane enables you to document project data such as model elements, shapes or diagrams either in written or verbal form. For written content, it can be a plain text or HTML text with formats like bold, italic, table, etc.
The Documentation pane
The toolbar
NameIcon Description
HTML
It enables you to read and edit 3 different types of content. The 3 types of content include HTML, HTML Source and Plain Text.
HTML: Read and edit the original content.
HTML Source: Read and edit the HTML source of content.
Plain Text: Read and edit content without formats.
Bold
Set the highlighted text to bold.
Italic
Set the highlighted text to italic.
Underline
Underline the highlighted text.
Left Justify
Set the alignment of highlighted text to left.
Center Justify Set the alignment of highlighted text to center.
Right Justify Set the alignment of highlighted text to right.
Ordered list Add a numbered list.
Un-ordered list
Add a list with bullet points.
Font
Select the font family of highlighted text.
Font size Select the size of highlighted text.
Font color Select the color of highlighted text.
Table Add a table. A few formats of insertion for rows and columns can be selected, including: Insert Row Above, Insert Row Below, Insert Column on Left and Insert Column on Right.
Insert Row Above: Insert a row above the row you selected.
Insert Row Below: Insert a row below the row you selected.
Insert Column on Left: Insert a column on the left of the column you selected.
Insert Column on Right: Insert a column on the right of the column you selected.
Background color Select the background color of highlighted text.
Clear formats
Clear formats of whole editor to convert the content to plain text.
Link Add a hyperlink in a specific place of documentation pane.
Image Add an image in a specific place of documentation pane.
Add Model Element   Add a model element in a specific place of documentation pane.
Save as template... Save the documentation as template.
Manage Template... Preview or delete a saved template.
Print
Print the custom content.
The description of icons on documentation pane's toolbar
Close and open the Documentation pane
Documentation pane is opened by default. To close it, press the X button at the top right corner. On the other hand, you can open it by selecting View > Panes > Documentation from the main menu.
Document project data in text
Documentation pane enables users to type in the textual description for project data, for instance, model elements, shapes and diagrams.
Define a glossary item
A word or lexis can be defined as a glossary item for explication.
  1. Highlight the word or the lexis you would like to be defined and then right click on it. Select Add "..." to Glossary from the pop-up menu to switch to Glossary Grid.
    Select Add "premium plan" to Glossary from the pop-up menu
  2. In Glossary Grid, you can right click on a term and select Open Term Editor from the pop-up menu in order to fill more details about the new item. Altenatively, you can also click Open Term Editor button.
    Click Open Term Editor button
  3. In Term Editor page, click Add button to type the alias for the new item.
    Add an alias
    Add an alias
  4. Further information about the new item can be given by typing in the space under Definition.
    Enter term definition
  5. Finally, click OK to confirm editing. The window will then return to Glossary Grid.
  6. Moreover, you can insert as many new terms as you prefer. In Glossary Grid, click  to create another new term.
Check spelling
When you type an incorrect word carelessly, documentation pane can offer you a help.
For correcting a word, right click on the incorrect word with a red curved line and select one out of the suggested words from the pop-up menu.
Select a correct word from the pop-up menu
Moreover, you can add a new word to the dictionary if the word you typed is a rare word or a newly created word. Right click the new word and select Add to dictionary from the pop-up menu. When you type the word next time, it won't be marked as an incorrect word again.
Document a shape in voice
In addition to textual description, documentation pane also enables users to document for project data in verbal form.
Click Record... button for recording voice.
In Record Voice dialog box, enter the name for the audio clip. Click Record button to start recording while click Stop button to terminate. Click OK button if you want to save the voice recording; click Cancel button, and vice verse.
Name Icon Description
Record
  Press it to start recording.
Play Press it to play the voice you recorded.
Stop   Press it to stop recording.
Clear
  Press it to clear the voice you recorded.
The description of icons on Record Voice dialog box
8. Diagram overview Table of Contents 10. Stencil pane
Product
Try this feature with
Business Process Visual ARCHITECT
Technical Support
Sales Support
Discussion Forum
