Technical Support
Sales Support
Visual Paradigm is the first vendor to introduce the resource centric diagramming interface. The resource centric interface greatly improves the efficiency of modeling. It can make sure the modeler is able to create a diagram with correct syntax more quickly. The utmost importance thing is that you don't have to go back and forth between the toolbar and the diagrams for creating diagram elements, making connections and modifying the diagrams.
| Resource centric interface on task |
| NOTE: | To check or uncheck the options (including Resources, Group Resources, Extra Resources and Generic Resources Only) on resource centric interface, select View > Resource Centric from the main menu. |
Instead of clicking shapes one by one from the diagram toolbar, you can create another shape from an existing shape on the diagram.
| Create a task with resource centric interface |
| Release the mouse to create task |
For relating two shapes together, you have to link a shape to another. With resource centric interface, you can not only link them up, but also select an appropriate relationship for them.
| Select a resource icon |
| Two shapes are connected |
With quick connect, you are able to search the preferred shape and connect to it on the diagram accurately and quickly.
| Quick Connect dialog box |
| Task is spotlighted |
| Two shapes are linked |
| NOTE: | You should click the resource icon in accordance with the existing shapes on your diagram. If the shape does not exist on the diagram, the Quick Connect dialog box will not pop out even when you click the resource icon. |
Model transitor enables you to trace between model elements across different phrases of development. Once a transition is created between two shapes, you can navigate between them through the resource centric interface.
Move the mouse on a shape and select Model Transitor> Transit To and then select the shape's name you would like to transit to/from from the pop-up menu. As a result, the vision will be diverted to the selected shape after transition is selected. Thereafter, you can transit to/ from between these two shapes.
| Transit from one shape to another |
| NOTE: | Transition does apply not only on two shapes on the same diagram, but also two shapes in different diagrams. |
For providing extra information to shapes, you can insert both internal and external resources, such as a shape, a diagram, a file, a URL through the resource centric interface. After editing references, they can be opened throughout the resource centric interface.
| Add a file |
| Insert a file in Task Specification dialog box |
| The newly created reference |
Resource centric supports some connectors (e.g. Sequence Flow in Business Process Diagram) with splitting the connector by adding another shape.
| Press split resource icon |
| Two tasks are split by Gateway |
| NOTE: | The split resource icon is shown with orange asterisk. |
When a great amount of shapes are displayed on the diagram disorderly, resource centric interface can support alignment and grouping after selecting several shapes.
| Group Selection Resources are shown |
| Select Align Top from the drop-down menu |
| 1. Creating diagrams | Table of Contents | 3. Tagged values |
Technical Support
Sales Support
